Siemens struct datatype
Hello all,
I need help to get value from a struct Datatype of a Siemens S7-1500 .
i don’t know the syntax for getting “Vitesse” for exemple.
Thanks in advance :slight_smile:
You will need the OFFSET column for this one.
Thanks for your reply,
Yes, that’s what i did for other tags but in this case i don’t have OFFSET column.
Where can i find/add the column ?
Is this an optimized DB?
Saw this before, Question about “The optimized block access must be turned off” - Ignition - Inductive Automation Forum. Go and uncheck Optimized block acces for that DB.
It was an optimized block, i unchecked the Optimized Block acces for that DB, and now it’s ok.
Thanks everybody for your help !
Have a great day ! :slight_smile:
