I have 5 machines with S7-300 PLC.
I do not have problems with memory bits, word, double word, REAL,etc, addresing, but with the strings I cannot find the way.
For example, the tag is DB31.DBB0 , string type, array of 40 characters.
I tried [device_name]DB31,STRING0;
[device_name]DB31,ISTRING0;
[device_name]DB31,STRING0.40
It does not work.
Any help?
Does your memory area for the strings have the two leading bytes for max and current string length?
This one has the right syntax, so I’d at least hope the error or quality is different, which would lead to Phil’s question about the strings being in “S7 format”.
This is part of the tags list I got from the manufacturer, but I have also the PLC program, where I saw that the string length is 40 characters:
That's not an S7 string, that's simply an array of characters. So no, it doesn't have the leading two length bytes that Ignition expects.
Thank you, @pturmel and @Kevin.Herron
I used Kepserver with the same syntax. It works.
