Does anyone have experience with resetting the password on the Raven XE? I changed the default 12345 to something more complicated. The ACEManager accepted it, but upon reboot, I am unable to login. Can this unit be reset somehow? I tried the reset button for 30 seconds, but this didn’t work.
Also, I was trying to use the AT commands to view received SMS messages. In the ALEOS configuration, the ATSMSM2M is documented, but not much else. The AT+CMGL command (not in manual) only returns ERROR. In the IA setup document for the Raven, there is a command (atphonehome=1XXXXXXXXXX) that doesn’t appear in the ALEOS document, leading me to believe there are some other features. Does anyone know where to find this information?
Thank you much,
Matt
