Signal selection optimization in Ignition easyCharts
hello everyone!
I have a Tree View (Yuso, SCADA and EMS), where all are on a single EasyChart that share signals (tags). Now, the problem is that SCADA and Yuso contain the same, while EMS does not. So, I want a function that, when selecting EMS in the Tree View, will deselect the signals that are already selected to avoid problems.
I already have this implemented (I share the script).
	already_selectable = system.tag.readBlocking("[BALEN]System/Scada_control/Management/Topics Monitoring/already_selectable")[0].value
	desired_selectable = system.tag.readBlocking("[BALEN]System/Scada_control/Management/Topics Monitoring/desired_selectable ")[0].value
	if not desired_selectable and not already_selectable:
	    pensDataset = self.pens
	    modifiedRows = []
	    for rowIndex in range(pensDataset.getRowCount()):
	        row = [pensDataset.getValueAt(rowIndex, colIndex) for colIndex in range(pensDataset.getColumnCount())]
	      	row[7] = False
	        modifiedRows.append(row)
	        columnNames = list(pensDataset.getColumnNames())
	        newPensDataset = system.dataset.toDataSet(columnNames, modifiedRows)
	        self.pens = newPensDataset
	        system.tag.writeBlocking("[BALEN]System/Scada_control/Management/Topics Monitoring/already_selectable", True)
	elif desired_selectable:
	    system.tag.writeBlocking("[BALEN]System/Scada_control/Management/Topics Monitoring/already_selectable", False)
However, the problem is that the performance with this script is quite slow. I would like to know if there is any other method to achieve what I need.
cell update? i was thinking of an if = ems deselect enable colum..but I can't use conditions in those fields
I didn't look close, but you are constructing the dataset multiple times (for every row), instead of once after the loop.
You're also writing to the tag multiple times in the loop.
What recommendations would you give me? I could modify the script following your suggestions, but I would like to know if there is any other particular method that Ignition has to achieve what I need. The script is in an EasyChart configureChart.
Uploading: image.png…
Start with moving the constructing of the dataset after you have iterated through making modifiedRows
    tagsPaths = [
	tagsIn = system.tag.readBlocking(tagsIn)
	already_selectable = tagsIn[0].value
	desired_selectable = tagsIn[1].value
	    modifiedRows = []
	      	row[7] = False
	    self.pens = system.dataset.toDataSet(columnNames, modifiedRows)
thanks, I didn't know that readBlocking could read several tags at the same time.
Yes, but note that setting the pens is outside of the for loop. Your original script was making a new dataset, setting the pens, and writing to the tag each time it went through the loop. As @pturmel intimated, that is where your time is being taken up. The tag read at the beginning was a tiny optimaization compared to the loop. :slight_smile:
yes i see it! how can you change a code with so little heheh thank you very much. it's running much smoother now.
