I have a need to setup data entry form to be used on a Ipod based scanner. I can’t use the mobile because it can’t use a bar code scanner as an input. So I setup a HTML form page to use and it has four input fields and a submit button. I need to have the 4 input fields write the values to four existing memory tags in the ignition server when the submit button is pressed. Any help on the best way to get this to work would be appreciated. see HTML code below.
Lot Number<input type="text"name="lot_number"size="40"
BOL Number
<input type="text" name="bol_number"size="40"
PO Number
<input type="text" name="PO_number"size="40"
Resin Quantity Lbs
<input type="text" name="quantity"size="40"
