I've got a view in Perspective that shows several different simple gauges with different maxValues. I've noticed that when I increase the maxValue property the length of the background arc shrinks.
These 2 gauges will be set with bindings on the maxValues so they change based on what is being measured. When the view reloads, the background arc resets to the correct length, but with the bindings enabled they never reset. Below are the JSONs for both gauges and their parent containers
This is on Ignition 8.1.47
"type": "ia.container.coord",
"version": 0,
"props": {
"mode": "percent",
"style": {
"classes": "DashboardBox_Style",
"overflow": "hidden",
"overflowX": "hidden",
"overflowY": "hidden"
"meta": {
"name": "DashboardBox_1"
"position": {
"x": 457,
"y": 26,
"height": 219,
"width": 319
"custom": {
"PLCName": "PLC1",
"Title": "PandA Line 1"
"children": [
"type": "ia.chart.simple-gauge",
"version": 0,
"props": {
"value": 600,
"maxValue": 1200,
"arc": {
"width": 30,
"color": "#47FF47"
"arcBackground": {
"color": "#2B2B2B",
"opacity": 0.5
"label": {
"size": 30,
"color": "#000000",
"units": "CPH",
"maxDecimal": 0
"style": {
"classes": []
"meta": {
"name": "SimpleGauge"
"position": {
"x": -0.0408,
"y": 0.0594,
"height": 1.1416,
"width": 1.0815
"custom": {},
"propConfig": {
"props.label.units": {
"binding": {
"config": {
"path": "parent.custom.Metric"
"overlayOptOut": true,
"type": "property"
"persistent": true
"props.maxValue": {
"binding": {
"type": "property",
"enabled": false,
"config": {
"transforms": [
"fallback": 20,
"inputType": "scalar",
"mappings": [
"input": "CPM",
"output": 20
"input": "CPH",
"output": 1200
"input": "CPD",
"output": 28800
"outputType": "scalar",
"type": "map"
"props.value": {
"binding": {
"type": "property",
"enabled": false,
"config": {
"path": "parent.custom.Value"
"persistent": true
"type": "ia.display.label",
"version": 0,
"props": {
"text": "PandA Line 1",
"textStyle": {
"color": "#000000",
"fontSize": 22,
"fontWeight": "bold",
"textAlign": "center"
"meta": {
"name": "Title"
"position": {
"height": 0.1461,
"width": 1
"custom": {},
"propConfig": {
"props.text": {
"binding": {
"config": {
"path": "parent.custom.Title"
"type": "property"
"persistent": true
"propConfig": {
"custom.Location": {
"binding": {
"config": {
"expression": "replace({this.custom.Title}, \" \", \"_\")"
"type": "expr"
"custom.Metric": {
"binding": {
"config": {
"path": ".../InfoPanelContainer/MultiStateButton_Units.custom.State"
"transforms": [
"fallback": "",
"mappings": [
"input": 1,
"output": "CPM"
"input": 2,
"output": "CPH"
"input": 3,
"output": "CPD"
"type": "map"
"type": "property"
"custom.Value": {
"binding": {
"config": {
"fallbackDelay": 2.5,
"mode": "indirect",
"references": {
"Location": "{this.custom.Location}",
"Metric": "{this.custom.Metric}",
"PLC_Name": "{this.custom.PLCName}",
"Project_Name": "{session.custom.ProjectName}"
"tagPath": "[default]{Project_Name}/{PLC_Name}/HMI_{Location}_Rate/{Metric}_Current"
"type": "tag"
"version": 0,
"props": {
"mode": "percent",
"style": {
"meta": {
"name": "DashboardBox_2"
"position": {
"x": 789,
"y": 26,
"height": 219,
"width": 319
"custom": {
"PLCName": "PLC2",
"Title": "PandA Line 2"
"children": [
"version": 0,
"props": {
"value": 12,
"maxValue": 24,
"arc": {
"width": 30,
"color": "#47FF47"
"arcBackground": {
"color": "#2B2B2B",
"opacity": 0.5
"label": {
"size": 30,
"color": "#000000",
"units": "CPH",
"maxDecimal": 0
"style": {
"classes": []
"meta": {
"position": {
"x": -0.0408,
"y": 0.0594,
"height": 1.1416,
"width": 1.0815
"custom": {},
"propConfig": {
"binding": {
"config": {
"type": "property"
"persistent": true
"props.maxValue": {
"binding": {
"type": "property",
"enabled": false,
"config": {
"transforms": [
"fallback": 20,
"mappings": [
"input": "CPM",
"output": 20
"input": "CPH",
"output": 1200
"input": "CPD",
"output": 28800
"type": "map"
"props.value": {
"binding": {
"type": "property",
"enabled": false,
"config": {
"persistent": true
"version": 0,
"props": {
"text": "PandA Line 2",
"textStyle": {
"color": "#000000",
"fontSize": 22,
"meta": {
"name": "Title"
"position": {
"height": 0.1461,
"width": 1
"custom": {},
"propConfig": {
"props.text": {
"binding": {
"config": {
"type": "property"
"persistent": true
"propConfig": {
"binding": {
"config": {
"type": "expr"
"custom.Metric": {
"binding": {
"config": {
"transforms": [
"fallback": "",
"mappings": [
"input": 1,
"output": "CPM"
"input": 2,
"output": "CPH"
"input": 3,
"output": "CPD"
"type": "map"
"type": "property"
"custom.Value": {
"binding": {
"config": {
"mode": "indirect",
"references": {
"type": "tag"
