I´m trying to add some format into a Gauge value, but I can´t, any idea how to do so?
In a text field it comes by default
when I add it as a prop:
I got the error
You can't just add random props and hope they work.
How do you want the data formatted?
Thanks. Instead 1843828728 I would lke 1,843 mb
Are you using the comma as the decimal separator, or as the hundreds separator?
For the mb units you can add that to the props.label.units.
Right, we using . for milesimal separator here
I don't think you can have the number displayed with a comma as a hundreds seperator.
If your value of 1843828728 is actually 1843.828728, then you will need to do an expression on the value to divide your number by 1000000. And then set your props.label.maxDecimal the number of decimals you want to show.
ok thanks bschroeder
