Hello,
I would like to create a really simple java application to get some opc variables …
Is anybody can provide me some sample code ?
(connections to opc server, get tag values, etc.)
Many Thanks,
Laurent
Hello,
Many Thanks,
Laurent
You should be using a Java-based OPC-UA SDK to accomplish this, not the Ignition module SDK, which does not provide a general purpose UA SDK.
Try the Prosys client SDK… it looks pretty easy to get started with.
Is there any open-source alternative to this?
Not that I’m aware of.
Hello kevin
I am using the prosys OPC UA Java SDK and i dont understand from where i can start to develop the opc ua client
what will be the first step to develop a OPC ua client in java.
can you please help me how can i implement the code
Read the Prosys documentation.
I believe they have sample code as well.
You can connect to an OPC UA server via Node-RED… I’ve used it in the past for some quick mockups… Worth a look:
Granted, this doesn’t help you if you must have it in Java, but alas, it is a nice quick way to get some data out.
Hello Klevin,
yes they have a code inside , but i dont know how to use this sample code in my own application.
Can you please explain me what will be my first step for OPC UA java development
first i have create a client… how to create a client
second add the SDk
third add the Stack to the code
This is right or something else i have to do
Please explain…thanks in advance
best regards
SAM
One more thing i dont understand anything from the prosys documentation.
