Simple xml parsing question
I have basically no experience parsing xml in Ignition / Python. I'm trying to figure out the easiest way I can parse the following xml:
<?xml version=1.0 encoding=utf-8?><serial>XA8287</serial>
...such that I can get the serial into a string for further manipulation. The serial in question here would be XA8287. This is taking place within a Web Dev script, Ignition version 8.1.32.
Do I need to import DocumentBuilderFactory as explained in this page? Or would the SAX Parser be better? I feel like I could arrive at something workable by playing around a bit but I have no idea what the 'best practice' method would be here...
For a small XML document like your example the DOM Parser / DocumentBuilderFactory example should be easier.
SAX (streaming) is harder to use but better memory-wise when dealing with large documents.
There's also the Python etree library you can probably find examples for here in the forum, but I think there's historically been weird / hard to track down errors when using that...
Related:
I highly recommend using my wrappers around java's native XML handlers.
Edit: This might be more helpful:
The element tree library seems to be working ok for now:
def doPost(request, session):
	import xml.etree.ElementTree as ET
	xml = str(request['postData'])
	root = ET.fromstring(xml)
	serial = root.text
And then it gets used once more at the end, after I construct an xml string:
	root = ET.fromstring(xml_string)
	return root
IIRC, it can break if you feed it some unicode.
Don't use jython/python stdlib packages for things that can be done with java standard libraries.
