Simplifying Source Path for Alarms
I am running Ignition v8.1.37. On my alarm status table, I wish to simplify the way the source path is displayed. For instance, currently for all of my tags, the source path is represented as: prov:default:/tag:TagPath:/alm:Message. I am looking for a way to just display something just the TagPath in that column. I was thinking of a way using custom parameterized expressions or something but couldn't get far with that.
Did you add a display path to your alarm?
Anyone found a solution for this? Currently having the same challenge here. I am already using DisplayPath to display the department responsible to look at the alarm. I would really need to simplify the source path to something more readable
I'd suggest creating a new topic.
The discussion here, may be of interest to you.
Hi Andrews, sorry I am a bit new. Do you mean a new property for the alarm? Like a custom property?
Thank you very much Irose. Indeed what I am trying to achieve is that my email notification instead of displaying:
"AL006" at "prov:default:/tag:Tiofarma/OB/HB1/Preparation_weighing_CZV/0210_TubeFiller1/AL006/AL006:/alm:AL006" became active at 04:51:06
That they display something like:
"AL006" at "0210_TubeFiller1" became active at 04:51:06
Thank you very much for your guidance
The alarm properties “Label” and / or “Display Path” can be used to define nicer messages for the alarm to display, both in the alarm status tables and in email notifications.
