Is there a way to setup SSO with a default login backup? We have users that access Ignition from a variety of different ways. I want to enable single sign on, but I don’t want to lose the benefit of being able to monitor the system without a password. Currently we auto-login a guest username and then have the user login when/if they want to make changes only.
It would be great to try to login with the current user, but if they aren’t using a domain computer, fall back on the guest username, but I dont see an option for that. Is there a scripting method or some workaround I could use?
Thank you
On v7.9.13
