Hi there,
Is it possible to change the size of DateTimeInput component?
Hi there,
This looks like a Perspective question. Add the tag to your question title to make it clear (and to attract the right people).
Change what? The box? The numbers? The arrows? The whole lot?
You need to modify the CSS associated with the DateTimeInput.
.iaTimePickerInput .timePicker input {
height: 50px; // <---
width: 50px; // <---
text-align: center;
.ia_inputField {
font-size: 1.875rem; // <---
color: var(--neutral-90);
border: var(--containerBorder);
background-color: var(--input);
padding: 0px 0.5rem;
border-radius: var(--borderRadiusInput);
.iaTimePickerInput .timePicker .separator {
display: flex;
align-items: center;
justify-content: center;
font-size: 16px; // <---
text-align: center;
width: 11px;
height: 32px;
.iaTimePickerInput--wrapper button.left, .iaTimePickerInput--wrapper button.right {
width: 44px; // <---
Thank you so much! I found the rules for the size as you said. Problem is im running Ignition Maker edition, and it seems like i dont have the advanced stylesheet options? ![]()
You've tagged your question as Ignition instead of Maker. You haven't added the Perspective tag as requested. Why?
Perspective is implied if it's a Maker project as it doesn't support Vision, I think.
Sorry. This is my first topic on this forum, i dont know how to do that
There's a 🖉` pencil icon beside your post title ...
OK, so i fixed that, also i moved it to the maker category. Anyways, so I can not change the size of this object in maker?
I was able to use the Advanced Stylesheet and can make some things a bit smaller but the overall object is the same height and adds a scroll bar.
With the flex container at 60px the time object still wants 78px for some reason.
/* Direct stylesheet authoring is an advanced feature. Knowledge of CSS required.*/
height: 22px; // <---
text-align: center;
.iaTimePickerInput .ia_inputField {
font-size: 0.875rem; // <---
display: flex;
text-align: center;
width: 11px;
height: 22px;
.iaSelectCommon_select {
margin: 0;
border: 0;
cursor: pointer;
text-align: left;
height: 20px; // <---
appearance: none;
-webkit-appearance: none;
-moz-appearance: none;
padding-right: 16px;
padding-left: 5px;
Long time later, but you were probably running an older version of Ignition before the adv stylesheet was added
I'd be looking at the dev tools in the browser at the Styles applied to the components to see what's going on
That is how I found what I did find but I could not find anything that affected the entire object, only things inside it.
