I’m using 7.3.4 and have noticed a few things that could be fixed and improved
-Table columns don’t keep widths. This is something that appears to be patchy. On some screens they do, on others they don’t. Sometimes one table on a screen will keep its column widths and another table will not. weird
-Everytime a tag is changed the tag browser window scrolls to the top level. Irritating if you have several thousand tags (even if you have folders)
-Consistent fonts and sizes between components (i.e. numeric display and numeric entry - dialog plain 12 vs monospaced plain 14)
-Color control on easy chart trends and legends (the addition of the “Editor background” color attribute from the date range control to the easy chart should give me all the control I need).
-Numeric labels. To make it easier to create multiline labels can we have a something like
be the default? (Or just make it so that words wrap by default and use the existing horizontal alignment controls in the property editor to drive their behavior
-Notes window: this is hard to tell what it is bound to when you pull it up. It would be more functional if this were bound to the current foreground window in the editor. Changing the foreground window should change the notes window binding.
-The Notes window should also be dockable.
Just trying to point out some items that might help the designer experience ‘flow’ more.
