We have a customer that is wanting to display current data i.e OEE and line status on TV located throughout the plant. I’m looking for suggestions on what type of hardware I could use to do this.
I would think you could just use Ethernet cable and plug it into the network, but I’m finding it hard to see if the TV will run Java.
I use a couple of Samsung 400UXN-2 displays here. They have WinXP Embedded on board and the Java install was no issue.
Thanks for posting that, Jordan.
Those look pretty dang cool. It looks like the 400UXN-3 is the current model now. Wonder if I can convince the others we need one to play around with…
I was reading through the user manual a bit and it looks like there is a MagicInfo module that goes with it, is that the “PC” or is that something different? I am going to need a display like this sometime in the future so I’d like to figure out what all I’ll need.
The display will be in a washdown room as well so how would you deal with a mouse/keyboard if the display is in a IP65/66 enclosure? Some kind of USB extender or KVM extender?
The manual kind of stinks.
MagicInfo is an app installed on the PC.
Wonder if there’s a wireless kb that’s washdown ready…
We have used these keyboards in grain mill plants very dusty and nasty environment and they hold up well.
I use standard HD monitors up to 46" and repurposed PC’s that are in their golden years. When the monitor is a long distance from the PC (usually the case) I then use a VGA over CAT5 extender which is available from TruLink:
http://www.cablestogo.com/product.asp?cat_id=7026&sku=39959
They have multiport versions too.
