Socket Time Out
Dears
I have startup script with socket, when i update script and save project i get error below:
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:341)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:501)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:273)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:905)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.pushProject(GatewayInterface.java:951)
at com.inductiveautomation.ignition.designer.project.PushTask.run(PushTask.java:19)
at com.inductiveautomation.ignition.client.util.gui.ProgressDialog$TaskRunner.run(ProgressDialog.java:364)
Caused by: java.net.SocketTimeoutException: Read timed out
at java.base/java.net.SocketInputStream.socketRead0(Native Method)
at java.base/java.net.SocketInputStream.socketRead(Unknown Source)
at java.base/java.net.SocketInputStream.read(Unknown Source)
at java.base/java.io.BufferedInputStream.fill(Unknown Source)
at java.base/java.io.BufferedInputStream.read1(Unknown Source)
at java.base/java.io.BufferedInputStream.read(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.base/java.net.HttpURLConnection.getResponseCode(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:421)
… 7 more
Ignition v8.0.2 (b2019060511)
Java: Azul Systems, Inc. 11.0.3
Without seeing the script, it’s tough to diagnose.
It looks like something in the gateway is preventing a normal response. Look in the gateway log for possible errors.
