SOLVED_ Chart on Vision Client Vs Charts on Designer
Hello
I am a new to this amazing SCADA, I am still trying the demo one (two hours) I have been trying out the charts, they work super however, when i launched the vision client all readings are fine except charts- see the attached
fine in the designer,
Under project properties, Vision, Permissions, make sure legacy database access is permitted.
Thank you so very much for your quick reply. it worked fine, I enabled the tag history, instead.
thank you once again- Highly appreciated
