I have problem formating my date to pass it to a Popup params
Here is my code:
def runAction(self, event):
Fired when a row in the table is clicked.
Arguments:
self: A reference to the component that is invoking this function.
event: An object with the following attributes:
row (int): The unique row index as it is represented in the source
data. Also known as the row ID.
rowIndex (int): The row index as it is represented in the current
visible data.
value (dict): The row's value as a JSON object.
json = event.value
myDate = json["shift_date"]
system.perspective.togglePopup("tblEffTS","DruEfficaciteTypeStation", params = {'sDate':myDate})
The input data in the table is a string with a date format “yyyy-MM-dd” from SQL Query but is pushed as a string.
Somewhere this string is recognized as a date and is translated in “Fri Jun 10 2022 00:00:00 GMT-0400 (heure d’été de l’Est)” in json[“shift_date”]
I don’t know how to keep this string as a string in the process or to translate back the json value “Fri Jun 10 2022 00:00:00 GMT-0400 (heure d’été de l’Est)” to my original format “yyyy-MM-dd”.
Thanks for your help
Hi Jonathan,
Have you tried the system.date.format system function? That should let you maintain your desired format through your script. Give that a try and let us know if it does what you need.
Hope this helps!
Hi jthorpe,
Thanks for your responce. I already try to use the function system.date.format on json[“shift_date”]. But the system don’t recognize the format as a date to transform into a string. There is already a prior transformation into json[“shift_date”] which is a string with the format “Fri Jun 10 2022 00:00:00 GMT-0400 (heure d’été de l’Est)”
But you gave me the idea to pre format the date in the table to force a format .
Here is my code:
output_json = [ ]
style_red = {"color":"#ff0000"}
style_green = {"color":"#00ff00"}
for row in range(value.getRowCount()):
row_object = {}
row_value = {}
row_style = {}
for col in range(value.getColumnCount()):
row_value[value.getColumnName(col)] = value.getValueAt(row,col)
row_object['value'] = row_value
if value.getColumnName(col) == 'pctEffAdjDrummond':
if value.getValueAt(row,col) >= 1.02:
row_style = style_green
elif value.getValueAt(row,col) < 1.02:
row_style = style_red
row_object['style'] = row_style
if value.getColumnName(col) == "shift_date":
row_value['shift_date'] = system.date.format(value.getValueAt(row,col),"yyyy-MM-dd")
output_json.append(row_object)
return output_json
This have made the trick.
Sorry, it’s look like I didn’t have the right format for the forum code quote.
Use > for quoting text written by someone else.
Use </> for code or put ``` on the line before the code and again on the line after. (That’s what the </> button does.)
Click the pencil icon to edit your previous post.
I used:
[code] [/code]
