[SOLVED] Deleting rows from a SQL table using RunPrepQuery
I have some code here that lets the user drag and drop data from one power table to the next:
if system.gui.confirm("Are you sure you want to scrap this part?", "Recycle?"):
	if self != sourceTable:
		destDataset = self.getData()
		pyRowData = system.dataset.toPyDataSet(rowData)
		for row in pyRowData:
			newRow = []
			for column in row:
				newRow.append(column)
			destDataset = system.dataset.addRow(destDataset, dropIndexLocation, newRow)
		self.setData(destDataset)
		system.db.runPrepQuery("DELETE FROM my_Table WHERE RFID = ?;", [destDataset.getValueAt(0,0)])
		sourceTable = results
	else:
		system.gui.messageBox("Dropping on to same table not supported")
However it seems that no matter what syntax I try the sql table is never actually updated. Does anyone know what my runPrepQuery is missing?
Try using system.db.runPrepUpdate()
That worked thank you. Is there a way to also delete the row I copied into the destination power table?
newDataset = system.dataset.deleteRows(self.getData(), rows)
self.setData(newDataset)
The above isn’t cutting it…
Have you tried
self.data = newDataset
Yes, did not work.
self.data = system.dataset.deleteRow(self.data, 0)
This worked for me.
Glad you got it sorted out! :slight_smile:
