[SOLVED] Does anyone know how to make a WebRequest in Python/Ignition?
Good morning,
I am converting the following code:
myRequest = (HttpWebRequest)WebRequest.Create(this.URL); // create request
myRequest.Headers.Add("Authorization", "Basic " + Convert.ToBase64String(Encoding.ASCII.GetBytes(this.BasicAuthAccount + ":" + this.BasicAuthPassword)));
myRequest.Method = Method.ToString();
myRequest.KeepAlive = false;
myRequest.ContentType = "application/x-www-form-urlencoded";
myRequest.ReadWriteTimeout = 1000;
if (this.HasData)//Append data for send
    byte[] byData = Encoding.ASCII.GetBytes(this.JsonifyString); // convert POST data to bytes
    myRequest.ContentLength = byData.Length;
    // Add the post data to the web request
    outputStream = myRequest.GetRequestStream();
    outputStream.Write(byData, 0, byData.Length);
    outputStream.Close();
I think I use this Ignition method:
https://docs.inductiveautomation.com/display/DOC81/system.net.httpPut
And I came up with the following code:
url = "http://192.168.1.7/do_value/slot_0/ch_0"
contentType = "application/x-www-form-urlencoded"
putData = {"Ch":0, "Val": 0}
connectTimeout = 1000
readTimeout = 1000
username = "root"
password = "00000000"
system.net.httpPut(url, contentType, putData, connectTimeout, readTimeout, username, password)
And I packaged this code into an Ignition button script and am getting the following error:
  File "<event:actionPerformed>", line 10, in <module>
IOError: Unexpected end of file from server
Does anyone know what this error means?
You’re better off using system.net.httpClient - Ignition User Manual 8.1 - Ignition Documentation and then from there using the .put() method. Try it with httpClient first and see if the issue persists.
I think you’re trying to use the POST method, not PUT (based on comments in what you’re trying to replicate), so that could be part of the problem as well.
I am getting a response 411 length required.
Try sending the JSON as data, not params. Right now you are calling PUT with an empty request body.
That was the key… thank you Kevin and others.
