[SOLVED] How to set a button border color dynamically?
Good afternoon,
How would I set a vision button’s border dynamically? The following expression works fine.
toBorder("matte;'0, 255, 255';5;5;5;5")
However this does not work fine
toBorder("matte;{tagPath};5;5;5;5")
This also doesn’t work…
toBorder("matte;runScript('myScript.getColor()');5;5;5;5")
Thanks for any input.
you should be able to do it with something like this: toBorder("matte;" + {tagPath} + ";5;5;5;5")
I followed your suggestion and also added a custom property called myColor with the following expression binding:
And then using your syntax:
toBorder("matte;" + {component.customPropertyPath} + ";5;5;5;5")
And it works!
Thanks!
