[SOLVED] How to use parameters in an alarm expression on a UDT?
Good morning,
I can’t seem to solve this problem. I have a UDT with 100 instances of my tag and each tag has some string and integer parameters.
I add an alarm Expression that uses the parameters.
#Source is a string parameter
#Path is an integer parameter
{Source} + " path " + {Path} + " active for too long."
However, this evaluates to a full path
prov:myProvider:/tag:somePath/Path/4/Paths_Timer:/alm:Paths_Timer 4 active for too long.
But what I really want is this:
North path 0 active for too long
Thoughts on what is wrong with my syntax?
You are using parameter names that have predefined meanings. Don’t use those names.
