[ SOLVED ] IGNITION ERROR java.lang.NullPointerException
Good morning!
When a I clic on a tab of the tab strip component, will open a window that is going to show a Piechart with stadistics and a table with information, both components have queries but I got this error, I am not sure if is for the chart.
Also, my window is very slow to charge the complete window and sometimes ignition get slow, I tried to remove or change some things that were consuming memory.
Can someone explain me please?
And let me know if you need to see the queries.
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
	at com.inductiveautomation.ignition.common.BasicDataset.getValueAt(BasicDataset.java:122)
	at com.inductiveautomation.factorypmi.application.binding.util.NonSerializingDataset.getValueAt(NonSerializingDataset.java:68)
	at com.inductiveautomation.factorypmi.application.components.chart.runtime.FPMIPieDataset.getValue(FPMIPieDataset.java:68)
	at org.jfree.chart.plot.PiePlot.getLegendItems(PiePlot.java:2903)
	at org.jfree.chart.title.LegendTitle.fetchLegendItems(LegendTitle.java:405)
	at org.jfree.chart.title.LegendTitle.arrange(LegendTitle.java:486)
	at org.jfree.chart.JFreeChart.drawTitle(JFreeChart.java:1322)
	at org.jfree.chart.JFreeChart.draw(JFreeChart.java:1212)
	at org.jfree.chart.ChartPanel.paintComponent(ChartPanel.java:1361)
	at com.inductiveautomation.factorypmi.application.components.PMIPieChart.paintComponent(PMIPieChart.java:173)
	at java.desktop/javax.swing.JComponent.paint(Unknown Source)
	at java.desktop/javax.swing.JComponent.paintChildren(Unknown Source)
	at com.inductiveautomation.vision.api.client.components.model.AbstractVisionPanel.paintChildren(AbstractVisionPanel.java:304)
	at java.desktop/javax.swing.JLayeredPane.paint(Unknown Source)
	at java.desktop/javax.swing.JViewport.paint(Unknown Source)
	at java.desktop/javax.swing.JComponent.paintToOffscreen(Unknown Source)
	at java.desktop/javax.swing.RepaintManager$PaintManager.paintDoubleBufferedImpl(Unknown Source)
	at java.desktop/javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(Unknown Source)
	at java.desktop/javax.swing.RepaintManager$PaintManager.paint(Unknown Source)
	at java.desktop/javax.swing.RepaintManager.paint(Unknown Source)
	at java.desktop/javax.swing.JComponent._paintImmediately(Unknown Source)
	at java.desktop/javax.swing.JComponent.paintImmediately(Unknown Source)
	at java.desktop/javax.swing.RepaintManager$4.run(Unknown Source)
	at java.desktop/javax.swing.RepaintManager.paintDirtyRegions(Unknown Source)
	at java.desktop/javax.swing.RepaintManager.prePaintDirtyRegions(Unknown Source)
	at java.desktop/javax.swing.RepaintManager$ProcessingRunnable.run(Unknown Source)
The dataset for your piechart has a null value (None) in it somewhere.
I saw that in my piechart I did not had a row , so it was null, so, I just added a row and it worked.
Thank you so much!
I tried again but the error still there
	at com.inductiveautomation.factorypmi.application.binding.util.NonSerializingDa`Preformatted text`taset.getValueAt(NonSerializingDataset.java:68)
	at com.inductiveautomation.ignition.designer.designable.DesignPanel$DesignableContainerLayer.paintChildren(DesignPanel.java:1159)
What version of Ignition are you on? Are you using row or column order?
version 8.1.11, did not work what I tried and I am using a row order
You may need to upgrade to Ignition 8.1.14 or later. It looks like you're running in to a bug that we fixed in that version.
Ok. because I am getting the info by a named query and if I have a license key, what will happen?
I'm not sure I understand your question. But there's no work around for the bug and the upgrade is free, if that helps.
Let me check, I am installing a different version
I installed the 8.1.30 and it worked, thank you so much
Where can I have the datasheet that says that X version has bugs?
That doesn't exist, however there are changelogs that list the bugs fixed in each release.
Each version on the downloads page has a release notes link: Current Ignition Release | Inductive Automation
Thank you so much
