- Installation using: ignition-7.4.2-linux-32-installer.run
- The installation didn’t automaticall find my java installation, but it continued after manually entering /usr/bin/java when it asked for the location
Below is the output from ignition.sh console. There are some “SEVERE Errors”.
Any ideas what’s wrong?
The teststation uses Debian squeeze with debian security packages (a.o. libservlet 2.5)
user1@teststation:/usr/local/bin/ignition$ ./ignition.sh console
Running Ignition Gateway...
WARN | wrapper | An encoding declaration is missing from the top of configuration file:
WARN | wrapper | /usr/local/bin/ignition/wrapper-license.conf
WARN | wrapper | trying the system encoding.
wrapper | --> Wrapper Started as Console
wrapper | Java Service Wrapper Standard Edition 32-bit 3.5.4
wrapper | Copyright (C) 1999-2010 Tanuki Software, Ltd. All Rights Reserved.
wrapper | http://wrapper.tanukisoftware.com
wrapper | Licensed to Inductive Automation for Ignition Gateway
wrapper |
wrapper | Launching a JVM...
jvm 1 | WrapperManager: Initializing...
jvm 1 | 1-mei-2012 11:25:03 org.apache.catalina.startup.Embedded start
jvm 1 | INFO: Starting tomcat server
jvm 1 | 1-mei-2012 11:25:03 org.apache.tomcat.util.digester.Digester startElement
jvm 1 | SEVERE: Begin event threw error
jvm 1 | java.lang.NoClassDefFoundError: org.apache.tomcat.util.modeler.ManagedBean
jvm 1 | at java.lang.Class.initializeClass(libgcj.so.10)
jvm 1 | at java.lang.Class.newInstance(libgcj.so.10)
jvm 1 | at org.apache.tomcat.util.digester.ObjectCreateRule.begin(ObjectCreateRule.java:206)
jvm 1 | at org.apache.tomcat.util.digester.Rule.begin(Rule.java:153)
jvm 1 | at org.apache.tomcat.util.digester.Digester.startElement(Digester.java:1358)
jvm 1 | at gnu.xml.stream.SAXParser.parse(libgcj.so.10)
jvm 1 | at org.apache.tomcat.util.digester.Digester.parse(Digester.java:1663)
jvm 1 | at org.apache.tomcat.util.modeler.modules.MbeansDescriptorsDigesterSource.execute(MbeansDescriptorsDigesterSource.java:232)
jvm 1 | at org.apache.tomcat.util.modeler.modules.MbeansDescriptorsDigesterSource.loadDescriptors(MbeansDescriptorsDigesterSource.java:211)
jvm 1 | at org.apache.tomcat.util.modeler.Registry.load(Registry.java:753)
jvm 1 | at org.apache.tomcat.util.modeler.Registry.loadDescriptors(Registry.java:865)
jvm 1 | at org.apache.tomcat.util.modeler.Registry.loadDescriptors(Registry.java:843)
jvm 1 | at org.apache.tomcat.util.modeler.Registry.findDescriptor(Registry.java:907)
jvm 1 | at org.apache.tomcat.util.modeler.Registry.findManagedBean(Registry.java:627)
jvm 1 | at org.apache.tomcat.util.modeler.Registry.findManagedBean(Registry.java:962)
jvm 1 | at org.apache.tomcat.util.modeler.Registry.registerComponent(Registry.java:793)
jvm 1 | at org.apache.catalina.core.StandardEngine.init(StandardEngine.java:308)
jvm 1 | at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:409)
jvm 1 | at org.apache.catalina.startup.Embedded.start(Embedded.java:825)
jvm 1 | at com.inductiveautomation.catapult.CatapultBase.startTomcat(CatapultBase.java:206)
jvm 1 | at com.inductiveautomation.catapult.Catapult.main(Catapult.java:74)
jvm 1 | at java.lang.reflect.Method.invoke(libgcj.so.10)
jvm 1 | at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:272)
jvm 1 | at java.lang.Thread.run(libgcj.so.10)
jvm 1 | Caused by: java.lang.ClassNotFoundException: javax.management.modelmbean.ModelMBeanNotificationBroadcaster not found in gnu.gcj.runtime.SystemClassLoader{urls=[file:/usr/local/bin/ignition/lib/wrapper.jar,file:/usr/local/bin/ignition/lib/annotations-api.jar,file:/usr/local/bin/ignition/lib/catalina.jar,file:/usr/local/bin/ignition/lib/catapult.jar,file:/usr/local/bin/ignition/lib/el-api.jar,file:/usr/local/bin/ignition/lib/log4j-1.2.15-min.jar,file:/usr/local/bin/ignition/lib/servlet-api.jar,file:/usr/local/bin/ignition/lib/slf4j-api-1.5.3.jar,file:/usr/local/bin/ignition/lib/slf4j-log4j12-1.5.3.jar,file:/usr/local/bin/ignition/lib/tomcat-coyote.jar,file:/usr/local/bin/ignition/lib/tomcat-juli.jar,file:/usr/local/bin/ignition/lib/mail.jar], parent=gnu.gcj.runtime.ExtensionClassLoader{urls=[], parent=null}}
jvm 1 | at java.net.URLClassLoader.findClass(libgcj.so.10)
jvm 1 | at gnu.gcj.runtime.SystemClassLoader.findClass(libgcj.so.10)
jvm 1 | at java.lang.ClassLoader.loadClass(libgcj.so.10)
jvm 1 | at java.lang.VMClassLoader.defineClass(libgcj.so.10)
jvm 1 | at java.lang.ClassLoader.defineClass(libgcj.so.10)
jvm 1 | at java.security.SecureClassLoader.defineClass(libgcj.so.10)
jvm 1 | at java.lang.Class.forName(libgcj.so.10)
jvm 1 | ...23 more
jvm 1 | 1-mei-2012 11:25:03 org.apache.catalina.core.StandardEngine init
jvm 1 | INFO: Error registering
jvm 1 | ...23 more
jvm 1 | SEVERE: java.lang.NoClassDefFoundError: org.apache.tomcat.util.modeler.ManagedBean
jvm 1 | 1-mei-2012 11:25:03 org.apache.catalina.core.StandardEngine start
jvm 1 | INFO: Starting Servlet Engine: Apache Tomcat/6.0.18
jvm 1 | 1-mei-2012 11:25:03 org.apache.catalina.core.StandardHost init
jvm 1 | SEVERE: Host registering failed!
jvm 1 | at org.apache.tomcat.util.modeler.modules.MbeansDescriptorsIntrospectionSource.createManagedBean(MbeansDescriptorsIntrospectionSource.java:292)
jvm 1 | at org.apache.tomcat.util.modeler.modules.MbeansDescriptorsIntrospectionSource.execute(MbeansDescriptorsIntrospectionSource.java:84)
jvm 1 | at org.apache.tomcat.util.modeler.modules.MbeansDescriptorsIntrospectionSource.loadDescriptors(MbeansDescriptorsIntrospectionSource.java:77)
jvm 1 | at org.apache.tomcat.util.modeler.Registry.findManagedBean(Registry.java:650)
jvm 1 | at org.apache.catalina.core.StandardHost.init(StandardHost.java:786)
jvm 1 | at org.apache.catalina.core.StandardHost.start(StandardHost.java:670)
jvm 1 | at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
jvm 1 | at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
jvm 1 | 1-mei-2012 11:25:03 org.apache.catalina.startup.DigesterFactory register
jvm 1 | WARNING: Could not get url for /javax/servlet/jsp/resources/jsp_2_0.xsd
jvm 1 | WARNING: Could not get url for /javax/servlet/jsp/resources/jsp_2_1.xsd
jvm 1 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_1_1.dtd
jvm 1 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_1_2.dtd
jvm 1 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_2_0.xsd
jvm 1 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_2_1.xsd
jvm 1 | 1-mei-2012 11:25:03 org.apache.catalina.core.StandardContext resourcesStart
jvm 1 | SEVERE: Error starting static Resources
jvm 1 | at org.apache.catalina.core.StandardContext.resourcesStart(StandardContext.java:3971)
jvm 1 | at org.apache.catalina.core.StandardContext.start(StandardContext.java:4126)
jvm 1 | at org.apache.catalina.core.StandardHost.start(StandardHost.java:719)
jvm 1 | 1-mei-2012 11:25:03 org.apache.catalina.core.StandardContext start
jvm 1 | SEVERE: Error in resourceStart()
jvm 1 | WrapperSimpleApp:
jvm 1 | WrapperSimpleApp Error: Encountered an error running main:
jvm 1 | at org.apache.catalina.core.StandardContext.registerJMX(StandardContext.java:5225)
jvm 1 | at org.apache.catalina.core.StandardContext.start(StandardContext.java:4291)
wrapper | <-- Wrapper Stopped
