bmeyers
September 17, 2020, 8:44pm
1
Good afternoon,
Is it possible to run system.gui.transform() synchronously? I want an animation to finish before I continue my script.
def myScript():
...do some stuf
system.gui.transform(350 ms)
...do some other stuff
Thanks for any help.
You can pass a callback function into the transform and it will execute that once the transform is done
bmeyers
September 17, 2020, 8:54pm
3
button1 = event.source.parent.getComponent('someButton')
rectangle = event.source.parent.getComponent('Rectangle')
p_Duration = 15000
p_Callback = NUMS.helloWorld()
p_FPS = 60
p_Accel = system.gui.ACCL_CONSTANT
p_Coord = system.gui.COORD_DESIGNER
rectX = rectangle.relX
rectY = rectangle.relY
rectWidth = rectangle.relWidth
rectHeight = rectangle.relHeight
NUMS.transform_This(button1, rectX, rectY, rectWidth, rectHeight,
p_Duration, p_Callback, p_FPS, p_Accel, p_Coord)
I have the above on the action Performed script of a button called “Button”. My function helloWorld() gets executed long before the animation finishes…
def helloWorld():
system.gui.messageBox('hello world')
You need to pass in the function definition. At the moment you’re executing the function and passing in its return value. Set p_Callback = NUMS.helloWorld instead
bmeyers
September 17, 2020, 9:03pm
5
I get the following error doing that.
p_Duration, p_Callback = NUMS.helloWorld, p_FPS, p_Accel, p_Coord)
Below:
Parse error for event handler "actionPerformed" SyntaxError: ('non-keyword arg after keyword arg', (' ', 16, 52, '\t\t\t\t\t\t\t\t\tp_Duration, p_Callback = NUMS.helloWorld, p_FPS, p_Accel, p_Coord)\n'))
The documentation says the callback function is a pyobject but i’m not sure what syntax that means for me.
I meant set it to that above where you’ve defined all your argument variables
bmeyers
September 17, 2020, 9:04pm
7
Nevermind. See below code.
p_Duration = 15000
p_FPS = 60
bmeyers
September 17, 2020, 9:05pm
8
Got it. Thanks for the help.
No worries, sorry if blunt, phone on 1% haha
