[Solved] Issue with ignition, conection
Hello everyone, I am having an issue with ignition , because I got an 503 error and is disconnected so many times and know says this :
java.lang.Exception: Error running query:
com.inductiveautomation.factorypmi.application.gateway.NQuery@3d2f7157@0ms
On: estadisticasCanales.Root Container.tblEsadisticasCaneles.data
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryExecutor.run(QueryManager.java:311)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Java heap space
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:325)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:945)
at com.inductiveautomation.ignition.designer.db.namedquery.DesignerNamedQueryManager.execute(DesignerNamedQueryManager.java:73)
at com.inductiveautomation.ignition.designer.db.namedquery.DesignerNamedQueryManager.execute(DesignerNamedQueryManager.java:46)
at com.inductiveautomation.factorypmi.application.gateway.NQuery.execute(NQuery.java:70)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$Query.execute(QueryManager.java:668)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryExecutor.run(QueryManager.java:308)
… 1 more
Caused by: java.lang.OutOfMemoryError: Java heap space
at com.inductiveautomation.ignition.client.gateway_interface.ResponseParser.startElement(ResponseParser.java:361)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:485)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:283)
… 8 more
Ignition v8.1.11 (b2021101912)
Java: Azul Systems, Inc. 11.0.11
Think this is the major issue here
We edit the ignition.conf and we set the maxime memory as the manual says, but do not do the change in the gateway
Did you turn the gateway service off and on again? You must do this for ignition.conf changes to take effect.
yes, I did it and the ignition.conf still has the change but I can not see it in the gateway.
Stil has 2 gb in the maxime but I update it to 4 gb and still says 2 gb
That generally means you have multiple ignition.conf files (leftovers from prior installs, perhaps) and you edited the wrong one.
Oh yes, thank you, I edit the wrong one
