Installing native client (linux 64bit arch) on a small format PC (AMD Ryzen 3 4300U/Video baked in AMD Renoir)
Ignition 7.9.18 ( b2021062913)
Cannot start client on X (xorg version 1.20.13-2) if I use the ignition supplied Zulu JRE. (9.0.7.2+1)
Works fine if I use a generic system Java (eg 8 JDK. 1.8.0-292-b10)
runtime/bin/java -jar app/native-launcher.jar
Yields log
INFO [ClientLauncher ] [11:21:35,154]: Using /home/ignition/.ignition/clientlauncher-data/clientlauncher.log to store logging info. Check there for all future logging events.
INFO [ClientLauncher ] [11:21:35,180]: Shortcut doesn't contain useBundledJre arg, defaulting to true
Problem invoking method public void com.inductiveautomation.ignition.client.nativelaunch.ui.component.ProgressBar.setOpacity(float) in object com.inductiveautomation.ignition.client.nativelaunch.ui.component.ProgressBar[,50,250,249x6,disabled,alignmentX=0.0,alignmentY=0.0,border=,flags=16777216,maximumSize=,minimumSize=,preferredSize=] in setValuejava.lang.reflect.InvocationTargetException
On my linux laptop it works fine (KDE/Arch also Xorg:1.20.13-2 i7-3740QM AMDGPU driver on AMD Radeon HD 7970M )
Problem persists if I switch Xorg to use vesa driver rather than AMDGPU.
At this point I'm assuming it is related to the CPU/Video card.
If others experience similar the easiest workaround is simply to remove/rename the runtime directory. int the clientlauncher directory.
