[SOLVED] New script not saving correctly still running old script 7.9.10
I have a script using the invokeLater() function that eventually opens a screen.
In my old script I had the line:
system.nav.openWindow('Main Navigation/_Navigation')
In my new script I have the line:
system.nav.openWindow('Main/_Navigation')
Now when I save to the gateway and run the new script I get the following error:
    File "<event:propertyChange>", line 31, in evaluateRFID
ValueError: Window Main/_Navigation does not exist.
at org.python.core.Py.ValueError(Py.java:309)
at
com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities$5.run(NavUtilities.java:431)
at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:810)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindowImpl(NavUtilities.java:359)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindow(NavUtilities.java:349)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilitiesDispatcher.openWindow(NavUtilitiesDispatcher.java:143)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:431)
at org.python.core.PyObject.__call__(PyObject.java:387)
at org.python.core.PyObject.__call__(PyObject.java:391)
at org.python.pycode._pyx1.evaluateRFID$1(<event:propertyChange>:34)
at org.python.pycode._pyx1.call_function(<event:propertyChange>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
at org.python.core.PyFunction.function___call__(PyFunction.java:376)
at org.python.core.PyFunction.__call__(PyFunction.java:371)
at org.python.core.PyFunction.__call__(PyFunction.java:361)
at org.python.core.PyFunction.__call__(PyFunction.java:356)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:649)
at com.inductiveautomation.factorypmi.application.script.builtin.ClientSystemUtilities$2.run(ClientSystemUtilities.java:361)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
Ignition v7.9.10 (b2018112821)
Java: Oracle Corporation 1.8.0_221
Does anyone know how I can reset the gateway to read my new script and discard the old script? I know it has something to do with the invokeLater() because I delete everything but the following:
system.gui.messageBox('hello')
and everything is fine. I put the new script back in and the error comes back.
Thanks for any help.
After carefully checking my syntax I found a user-error. The path name was not correct.
