[SOLVED] Open window in script tag changed
Yes. It worked as expected, which probably means I'm doing something differently. Which tag are you using to initiate the client tag change event script?
I am using Alarma_Canal_Vacio, let me check
btw, you don't need to use getCurrentValue() and getValue(), you can just use currentValue and value. E.g. currentValue.value and previousValue.value
I tried as your code but did not work, do you have other script in somewhere?
Hmmm. That's interesting, so when a session is first started, the very 1st time the popup opens, the correct tag values are not written to the labels, but every popup that occurs after does write in the correct values?
I think the project did not update well, because I close it and later it work about values but, do you think is possible use two tags for the tag change script and add information to the labels from two tags more if any of the two tag changes script is activated?
Yes; you can have multiple tag change scripts.
i want the same but for Perspective i cant solve my problem , help pls
Cool. If you haven't already, click the Topics button in the top left corner of the page.
Then, click the New Topic button at the top right corner of the page:
Fill out the form to ask your question, and most importantly, tag the question as Perspective using the optional tags dropdown:
This will attract the attention of the Perspective gurus that could possibly overlook this topic since it is tagged Vision.
