Good morning.
I have a function here:
def lookupStuff():
try:
system.gui.me//////ssageBox('doing some stuff')
except Syntax Error:
system.gui.messageBox('syntax error found')
A button on my GUI causes this function to run. When I run the above code nothing actually happens on the GUI. If I remove the syntax errors though i get the proper message “doing some stuff”.
With the GUI open I do ctrl+ shift + F7 and under the console I can see that SyntaxError did actually occur.
How can I get my try except SyntaxError to function properly?
SyntaxError - one word; it’s a constant.
Ok, so I fixed that. Thank you, but now I get the following error on my screen.
File "<event:mouseClicked>", line 1, in <module>
SyntaxError: ("mismatched input '\\n' expecting COLON", ('<module:project.lookupStuff>', 26,
21, '\t\t\tif stayInLoop == 1\n'))
You're opening a block (if stayInLoop == 1) but not terminating it with a colon.
Let me start over one more time. Under project I create a new script called ‘NewScript’. I type in the following code:
def lookupStuff():
try:
x=2
if x == 2
system.gui.messageBox('doing some stuff')
except SyntaxError:
On line 4 I can now see on the faaaaar right a red box appear telling me I have a SyntaxError. Instead of fixing the error I save the code and click my button which calls project.NewScript.lookupStuff().
Instead of a message ‘syntax error found’ I get an Error window with the following.
SyntaxError: ("mismatched input '\\n' expecting COLON", ('<module:project.NewScript>', 4, 11, '\t\tif
x == 2\n'))
Ignition v7.9.10 (b2018112821)
Java: Oracle Corporation 1.8.0_241
So what I think is happening if Ignition is saying I can’t run any code with SyntaxError. I will never get to except SyntaxError because Ignition won’t allow it to get that far.
Is that a true statement?
Not exactly. Python has to ‘run’ a module through once to ‘compile’ it; that’s where the SyntaxError is being thrown, not when actually calling your code. If you change your code at the call site to catch the SyntaxError, it should work; eg, in mouseClicked:
try:
exceptSyntaxError:
pass
Yep, that did the trick.
You also cleared up a lot of confusion about error catching so thank you for the help.
