[SOLVED] Unable to use system.tag.writeAsync in the script console
Good afternoon,
I am unable to run the following code in the Script Console. Anyone know what I’m doing wrong?
def callBack(arr):
    pass
path = "[MEPS]MerLine/General/del"
value = 108
system.tag.writeAsync(path, value, callBack)
Gives me the following error.
Java Traceback:
File "<input>", line 6, in <module>
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:1417)
at com.inductiveautomation.ignition.common.script.builtin.PyArgumentMap.coerce(PyArgumentMap.java:125)
at com.inductiveautomation.ignition.common.script.builtin.PyArgumentMap.interpretPyArgs(PyArgumentMap.java:81)
at com.inductiveautomation.ignition.common.script.builtin.PyArgumentMap.interpretPyArgs(PyArgumentMap.java:39)
at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.writeAsync(AbstractTagUtilities.java:368)
java.lang.ClassCastException: java.lang.ClassCastException: Cannot coerce value
'[MEPS]MerLine/General/del' into type: interface java.util.List
at org.python.core.Py.JavaError(Py.java:552)
at org.python.core.Py.JavaError(Py.java:543)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:524)
at org.python.core.PyObject.__call__(PyObject.java:515)
at org.python.core.PyObject.__call__(PyObject.java:519)
at org.python.pycode._pyx12.f$0(<input>:6)
at org.python.pycode._pyx12.call_function(<input>)
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.Py.runCode(Py.java:1614)
at org.python.core.Py.exec(Py.java:1658)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:131)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:605)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:593)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.ClassCastException: Cannot coerce value '[MEPS]MerLine/General/del' into type: interface java.util.List
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
... 19 more
java.lang.ClassCastException: java.lang.ClassCastException: Cannot coerce value '[MEPS]MerLine/General/del' into type: interface java.util.List
writeAsync expects a list of paths and values.
Try this instead:
system.tag.writeAsync([path], [value], callBack)
Thanks, I was looking at this way too long.
