I presume that there's no means to provide this type of authentication currently using the web dev module?
This seems like a little bit of work to set this up from scratch myself ![]()
Edit:
Perhaps I should have installed and used the webdev module before posting... I see now that it does have authentication based on Ignition user sources which you can provide via basic HTML authentication
