hi,
since i edited two windows from a Linux Java 6 Ignition Designer, i am no more able to open these windows in my main Java 7 Designer… i get this error
[code]com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error deserializing element “<c”
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.createException(XMLDeserializer.java:730)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementStart(XMLDeserializer.java:611)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:151)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:313)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:233)
at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:277)
at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:216)
at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:435)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$DesigntimeWindowOpener.openWindow(WindowWorkspace.java:3305)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openWindow(WindowWorkspace.java:1075)
at com.inductiveautomation.factorypmi.designer.workspace.StartupPanel$ResourceThumbnail.onClick(StartupPanel.java:335)
at com.inductiveautomation.factorypmi.designer.workspace.StartupPanel$ThumbnailButton$1.mouseClicked(StartupPanel.java:242)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: java.lang.IllegalArgumentException: Comparison method violates its general contract!
at java.util.ComparableTimSort.mergeHi(Unknown Source)
at java.util.ComparableTimSort.mergeAt(Unknown Source)
at java.util.ComparableTimSort.mergeCollapse(Unknown Source)
at java.util.ComparableTimSort.sort(Unknown Source)
at java.util.Arrays.sort(Unknown Source)
at java.util.Collections.sort(Unknown Source)
at com.inductiveautomation.factorypmi.plugins.reporting.components.FileExplorer$MyTreeNode.checkChildren(FileExplorer.java:226)
at com.inductiveautomation.factorypmi.plugins.reporting.components.FileExplorer$MyTreeNode.getChildCount(FileExplorer.java:337)
at javax.swing.tree.DefaultTreeModel.getChildCount(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache$TreeStateNode.expand(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache.ensurePathIsExpanded(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache.setExpandedState(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI.updateExpandedDescendants(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.treeExpanded(Unknown Source)
at javax.swing.JTree.fireTreeExpanded(Unknown Source)
at javax.swing.JTree.setExpandedState(Unknown Source)
at javax.swing.JTree.expandPath(Unknown Source)
at javax.swing.JTree.expandRow(Unknown Source)
at com.inductiveautomation.factorypmi.plugins.reporting.components.FileExplorer.createModel(FileExplorer.java:182)
at com.inductiveautomation.factorypmi.plugins.reporting.components.FileExplorer.(FileExplorer.java:79)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at com.inductiveautomation.factorypmi.application.xmlserialization.ComponentDeserializationHandler.startSubElement(ComponentDeserializationHandler.java:72)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementStart(XMLDeserializer.java:608)
… 48 more
Ignition v7.6.2 (b2368)
Java: Oracle Corporation 1.7.0_25[/code]
am i deadlocked?!
thank you
