Some inconsistencies with tag paths
HI,
I am making quite some progress with my Apache IoTDB tag historian, but currently struggling with a problem, that hopefully you folks here can provide some insights on.
I implemented the browse method of my history-provider and it nicely shows the tree of the data stored in IoTDB. However as soon as I pull over the tag in a report, it's path gets trucated to only contain the first path segment.
When the query executes, I only get the first two path segments even if I pulled one containing 4 over in the editor.
I'm using this code to create the results for each element of the tree:
                results.add(new BasicResult(root.extend("tag", childPath), hasChildren));
This results in this structure:
But in the createQuery and as you can see in the editor window in the Tag path column all I get are the first two path elements.
I tried creating a new QualifiedPath containng the original information in path element 0 and by appending "/{childName}" to the second path, but the Parser then creates 2 path elements one with "tag":"parentName" and one with null:"childName", so we're back to where I started.
Any suggestions on how to do this right?
Not sure. When rendered, all of the tag: parts should end up reported together, delimited by /. Have you tried playing with the QualifiedPath parser?
I did simply switch to generate them concatenated by appending {old-part}"." + {new-part} ... doesn't look pretty, but seems to pass the information I need.
As you can see something seems to be different with the way I built the paths as Ignition is only showing the first part in the editor.
The :/tag: delimiter should only exist once in the string render of a QualifiedPath. Find out why yours show repeats.
So what would be the id of the following parts?
They wouldn't have their own IDs. They'd be merged with the first :tag:/ with / separators.
I think you need to be modifying your childPath (assuming it's an instance of TagPath, e.g. childPath.getChildPath("next")), not always adding new tag elements to root.
