I tested the new user management and found some little issues:
- When tyring to delete a profile that is in use somewhere, the error message is not real helpful:
- When soft failover is used in an AD/Internal Auth Profile, and a user logs in the client with a failover account, the UserManagement component shows the users from the failover profile but the roles from the main profile.
It also allows editing of users from the failover profiles. Trying to add those users to one of the listed roles results in an exception of course.
Here the failover profile is the internal default profile.
ERROR [UserManagementPanel-AWT-EventQueue-0] Error saving user.
java.util.concurrent.ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.Long cannot be cast to java.lang.String
at java.util.concurrent.FutureTask$Sync.innerGet(Unknown Source)
at java.util.concurrent.FutureTask.get(Unknown Source)
at com.jidesoft.utils.SwingWorker.get(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.UserManagementPanel$UserEdit$SaveTask.done(UserManagementPanel.java:1011)
at com.jidesoft.utils.SwingWorker$5.run(Unknown Source)
at com.jidesoft.utils.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
at com.jidesoft.utils.AccumulativeRunnable.run(Unknown Source)
at com.jidesoft.utils.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
at javax.swing.Timer.fireActionPerformed(Unknown Source)
at javax.swing.Timer$DoPostEvent.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.Long cannot be cast to java.lang.String
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:313)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:244)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:797)
at com.inductiveautomation.factorypmi.application.components.UserManagementPanel$UserEdit$SaveTask.doInBackground(UserManagementPanel.java:998)
at com.inductiveautomation.factorypmi.application.components.managementpanel.AbstractManagerPanel$GatewayInvokeWorker.doInBackground(AbstractManagerPanel.java:129)
at com.inductiveautomation.factorypmi.application.components.managementpanel.AbstractManagerPanel$GatewayInvokeWorker.doInBackground(AbstractManagerPanel.java:125)
at com.jidesoft.utils.SwingWorker$1.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at com.jidesoft.utils.SwingWorker.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassCastException: java.lang.Long cannot be cast to java.lang.String
at com.inductiveautomation.ignition.gateway.authentication.impl.ADInternalHybridUserSource.findUserInternalId(ADInternalHybridUserSource.java:95)
at com.inductiveautomation.ignition.gateway.authentication.impl.ADInternalHybridUserSource.alterUser(ADInternalHybridUserSource.java:109)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper.alterUser(UserSourceWrapper.java:183)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.Users.alterUser(Users.java:280)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(null)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:176)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:377)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:861)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:606)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(null)
- There is also a potential concurrency problem. If two users add a role with the same name at the same time, the role is added twice to the database (Ok, this will not happen so often).
