Hi, I want to use drag and drop template canvas from Pefect Abstract, I use to play before in ignition 7.9 and it works very well. But in ignition 8.0 now its not work anymore. I found out 2 things and need help.
I can not get project resource filter by type name (string) anymore.
getResourceOfType(java.lang.String moduleId, java.lang.String type)
Any solution for this? -
So I do get all project resources and filter by ‘com.inductiveautomation.vision/templates’ but some templates when I use .getData() to return the resource data it is None .
Below here is the code.
Thank you.
from com.inductiveautomation.ignition.designer import IgnitionDesigner
context = IgnitionDesigner.getFrame().getContext()
if context is not None:
p = context.getProject()
#Down here I cannot get template resources as the same as in ignition v7.9
#p.getResourcesOfType(VisionClientInterface.VISION_MODULE_ID,"component-template")
templateResources = p.getResources()
#Loop through all the template information, store the template information and assign the templates to the template canvas.
i = 0
for index,r in enumerate(templateResources):
if str(r.getResourceType()) == 'com.inductiveautomation.vision/templates' and not (r.isFolder()):
resourceID = r.getResourceId()
fullPath = r.getFolderPath()
print fullPath
print r.getData() # Some templates return None
