Sort Columns in a specific Order Ignition Perspective
I have a table with n number of columns.
Few of these columns have the Field and Title property in Words all other are Numbers. Now when i populate this table, the columns with Number comes first and the columns with Words go to the last. I want to show the columns with the Words before the Numbers. I am not using bind data or named query. Everything is setup by the Python Script.
I have defined the columns order in the Columns property of the Table.
When I execute the same query in the workbench the intended order came up.
Is there a way to apply the order I need?
Have you specified the query column name in each columns.x.field property?
Yes I have.
OK, I see what you meant (and wrote!) in the original post.
Perspective - Table | Ignition User Manual says,
  • field: A string that matches this column config with a table column. This string must correspond to the default column name of the column. Value is string.
I think you're going to have to do some trickery.
  • Get the query to rename the columns using the AS function and add a leading alpha character.
  • Use those names in the columns.x.field properties.
  • Use the columns.x.header.title property to display just the number.
Thought of that, I thought maybe there is a way to define the custom order to put the columns.x.field with word before the numbers in ignition.
Anyways thanks. I will update the query.
No, I suspect that you've broken the table functionality by using a number in the data column name. If you're using JSON rather than a dataset the props editor won't even let you specify a value name beginning with a number.
Figure 1. Image source: JSON.org.
According to the image the key must be a string.
Ignition seems to tolerate incorrect JSON to some extent but the table can't make any sense of the columns if it's invalid. I don't know what happens with a dataset.
Oh I see, that's why it was working perfectly with the String field names and start behaving abnormally when I changed string to number. Thanks a lot for the in dept explanation.
