Sorting a table or sorting incoming data?
Have you defined myLogger further up in the script? If not then this wont work.
I did not. If I add the quotes around it, it should work correct?
I don't want to take this thread further off-topic, but a close example of SQLite in action that is familiar to everyone here is Ignition's own logs. The backing storage for these logs is a SQLite database.
Well that call at least should work.
Also, I edited my reply, did you see this?
Yes I beleive they do, here's a code snippet of how they are formatted. It's a newline and another one back to back.
  if not found_in_aoi:
            # Print the message that the tag was identified but not in any sector
            message = f"Tag ID: {hit_name} was identified, but it is not in any sector at {formatted_time}"
        result.append(message + "\n")
    messages = "\n".join(result)
    return messages
the variable messages is what is used to make up the data packet.
Should be alleviated with this:
Let's step back a moment. In what table is message being stored? According to the screenshot it's going into parsed_data. I would think it be saving into raw_data
You can download SQL Server developer edition which is the real thing but not to be used for commercial purposes. SQL Express is OK but has a 10 gig database limit
