In the alarm status/alarm journal components, is there a way to sort or edit what is visible in the alarm details window?
Dan
Dan
Both components user the Power Table, so you can right-click on the table header and select which columns you want to see and drag columns to reorder them. You can also click on a column header to order by that column. Click again to change the sort order and hold down while you click to sort by further columns.
Were you looking for something that was not met by this functionality?
