Sorting through a dataset
I have a dataset set to a custom param that I want to go through and remove rows where the IsValid column is true.
I think I can do this through a script transform
	valueDataset = system.dataset.toPyDataSet(value)
	validRows = [row for row in valueDataset if row['IsValid'] == True]
	return validRows
This works with returning the rows, but I need it back as a regular dataset. I tried toDataSet
    filteredDataset = system.dataset.toDataSet(validRows)
    return filteredDataset
but I'm getting a ScriptEval error because I think I need to give it column headers, which I have no idea how to do that.
edit: that being said, I feel like there should/could be a more elegant way of doing this, as I lose the column names when I convert toPyDataSet.
Thanks for the help!
getColumnNames() is what you're looking for. This should work with either dataset type.
	headers = list(value.getColumnNames())
	return system.dataset.toDataSet(headers, validRows)
That was it, thank you! I knew it would be something simple.
I appreciate your time!
