Hello,
Can anyone tell me what's wrong with this code ?
I have multipel condition to start the file Fault.wav but it's not playing it anyway !!
Try changing the clip's volume from integer to double. (1.0)
Your gateway might not have access to that directory. You can probably check the logs to get a better idea of why it isn't working. You could also try running the code without the optional volume and wait parameters, I seem to remember running into an issue with those a while ago...
When running sound clips in Vision, each Vision workstation must have the local sound files placed in the location used in the code.
