Continuing the discussion from How to set the Timestamp Source to Value on a tag:
Hello Colby,
I´m using the 8.1.18 version.
Transmiting Data trougth OPC UA to 3rd. parties, I´m having issues with the SourceTimestamp and the ServerTimestamp.
With a simple get_data_value query, I´m getting the correspondent SourceTimestamp and the ServerTimestamp. no issues.
But when suscribing to the same tag, SourceTimeStamp = ServerTimeStamp
Is there any configuration that I can perform in the gateway for ignition to send also the correct SourceTimestamp when suscribing?
Best Regards
Carlos Valencia
              I think this would need to be a change made to the Exposed Tags functionality. Right now it looks like Source and Server timestamps will always be the same when subscribing.
              I’ve created an issue in our internal tracker to fix this.
              Hello Kevin,
Thank you for the quick response.
Please give priority to this issue if possible.
This is affecting to all of our projects in Asset Digitization (more than 20 projects on production).
Best Regards
Carlos Valencia
              Hello Kevin,
Is there any update regarding the Source Timestamp issue with OPC UA?
Best regards
Carlos Valencia
Asset Digitization
APM Terminals Algeciras S.A.
Muelle Juan Carlos I, s/n
Algeciras (Cádiz), Spain
Mobile: +34 68 227 7250
Classification: Internal
              This was fixed and merged yesterday, it should be available in the nightly release available either now or tomorrow, depending on if/when it was built.
              Hello Kevin,
Thank you for the quick reply.
Will look then for the upgrade tomorrow.
Best regards
Carlos Valencia
Asset Digitization
