I have a Flex container and inside it i have a Flex Repeater and Label. On the Flex Repeater i have Labels which looks something like this.
when i have one instance.
when i have 2 instances.
i want it to look something like this without spacing.
You likely have a padding value set on your embedded view's root container. Adjust/remove that padding value and use gap in the flex repeater's props.style to control the spacing between instances.
