Spanish Character Issue
i am using this script in script console for handling spanish character but not working
def transform(value):
try:
corrected_text = value.encode('iso-8859-1').decode('utf-8')
except Exception as e:
return corrected_text
value = "testñ"
result = transform(value)
print(result) but its working in online python compiler , not working in ignition
Hello
Python relies on whitespace / indentation for scope which makes your provided code hard to read. When you make a post you can click on the 'cog wheel' settings icon and select 'preformatted text' which makes it a lot easier to read, e.g. see below.
	try:
value = "testñ"
print(result)
Without seeing an example of where this transform is actually used I can't be much help sorry but I think you might be being caught out with the fact that Python in Ignition is Python 2, not Python 3. Your 'online python compiler' is probably running Python 3. There were many changes between them, but one change was how unicode strings are handled. The 'Python 2' way of handling unicode is described here: https://docs.python.org/2/howto/unicode.html
For example, if I run the below code in Ignition (in the script console)
	try:
value = u"testñ"
print(result)
I get testñ. The change I made is adding the u to value = "testñ" to make value = u"testñ"
Hopefully this points you in the right direction
but when i am going to doing through this way in flex repeater component binding transform
response = system.net.httpGet(url = str(url),headerValues = headerValues)
dict = system.util.jsonDecode(response)
for i in dict['value']:
message_Content_old = (system.util.jsonDecode(i['attachments'][0]
['content'])['body'][3]['facts'][3]['value'])
val = u'{}'.format(message_Content_old)
message_Content = val.encode('iso-8859-1').decode('utf-8') not working
The u can only be prepended to string literals and has to go before the quotes. All it does is change the type of the string literal from being a string to a Unicode type. The code you have is just prepending a 'u' to the string.
I might have lead you astray with that comment, it was more to draw your attention to how Python 2 handles strings differently to Python 3, if so my apologies for that.
The actual solution to your problem is likely going to involve seeing exactly what bytes have been returned and figuring out how to go from there. I was able to get the following working
    corrected_text = value.decode('utf-8').encode('iso-8859-1')
    print(type(corrected_text))
value = "\xC3\x83\xC2\xB1"
print(value)
print(type(value))
print(transform(value))
which prints
ñ
<type 'str'>
<type 'str'>
ñ
But it assumes that the 'ñ' you get from your API endpoint is C3 83 C2 B1 (a UTF-8 ñ). I don't know for sure if that's the case though.
the thing is that, i am having customized keyboard in a view where spanish character is also there taking example
if value:
text = 'Ñ'
else:
text = 'ñ'
return text.decode('utf-8'). i am getting it correctly on label text of keyboard symbol . after that send this spanish symbol value to session params text2.getting this value into another view properly on label. and there is button which is used for post this data on teams channel
response2 = system.net.httpPost(url=contact, contentType="Application/Json", postData=json.dumps(webhookSkeleton))
through this way.
i am getting proper symbol on teams channel.
but when i use this into flex repeater for instances then i am having problem.showing wrong data ñ.
using this on flex repeater instances
message_Content = (system.util.jsonDecode(i['attachments'][0]['content'])['body'][3]['facts'][3]['value']), this message content i needed to show in flex reapeater instance but i am getting wrong display value
Maybe this can help you
by @pturmel
How to apply u literal before to make readable form for this
I am not getting it properly if i uses its value in script console as a string and applying u literal before it works fine but here how can i transform into u literal form
Any idea
Maybe
message_Content = unicode(system.util.jsonDecode(i['attachments'][0]['content'])['body'][3]['facts'][3]['value'])
or
message_Content = u"{}".format(system.util.jsonDecode(i['attachments'][0]['content'])['body'][3]['facts'][3]['value'])
What version of Ignition are you using?
Similar issues reported in kinds of embedded views in Perspective were fixed recently, e.g. [IGN-5692] Tagpaths with åäö not found in Embedded Veiw - #20 by PGriffith
Please see Wiki - how to post code on this forum. You can then edit each of your posts to correct them. Thanks.
in ignition i have one view and one view params Details where i am passing value is below:
(<div style="max-height: 300pxpx; max-width: 500px; border: 0px solid black; border-radius: 0px; background-color: white; padding: 5px;"><h3>testing the code</h3><p><strong>notification</strong></p><p>Sent feb. 28, 10:36 a. m.</p><table style= "border-width: 0px; border-spacing: 0px; border-style: none; border-collapse: collapse; display: block; overflow: hidden; box-sizing: border-box;"><tbody><tr><td>Department</td><td>dt123 car</td></tr><tr><td>Station</td><td>805000</td></tr><tr><td>Requested</td><td>TEST</td></tr><tr><td>Details</td><td>amú</td></tr></tbody></table></div>)
and take markdown component and on source i put params binding and take one transform script is
from HTMLParser import HTMLParser
	class HTMLCleaner(HTMLParser):
	    container = ""
	    key = ""
	    count = 0
	    def handle_data(self, data):
	    	if data == "Requested":
	    		self.key = "found"
	    	if self.key == "found":
	    		self.count += 1
	    	if self.count == 1 or self.count == 3:
	    		data += ": "
	    		self.container += data
	    	if self.count == 2 or self.count == 4:
	    		data += "<br>"
	    	return self.container
	h = HTMLCleaner()
	h.feed(value)
	v=h.container
	return v
i tried this also but not working return v.encode('latin1').decode('utf-8')
but i am getting data is below:
Requested: TEST
Details: amú
Its wrong i need correct data which is required correct data is amú.
amú is wrong display . please help and guide me
