Spanish Characters Encoding issue with Ignition while committing to SQL Server DB
We have some incoming inventory XMLs which has Spanish characters. We store the XML in a SQL Server DB table with XML datatype for the column. XML datatype already supports UTF-8 encoding, so there shouldn’t be any issue with storing Spanish characters.
If I directly use an insert command to store Spanish characters on SQL Server, they remain intact. But when I try to insert the XML using system.db.runUpdateQuery() with N’ ‘ prefix or system.db.runPrepUpdate with ? parameters from a script, the Spanish encoding breaks during storage in DB. Garbled characters get stored.
Has anyone else seen this behavior from Ignition script or know a fix for this ?
I also saw this old post. Not sure whether a similar issue could be there for XML data type on SQL Server DB - Special Characters
Maybe make sure you’re passing a real Unicode string from Jython u" befreo store it on the SQL Server
xml_u = unicode(xml_string) # or ensure it’s u"..."
system.db.runPrepUpdate("INSERT ... VALUES (?)", [xml_u], "CONN")
Tried this. Didn’t work.
I wonder if you need to also add the "u" in front of the SQL query like so:
system.db.runPrepUpdate(u"INSERT ... VALUES (?)", [xml_u], "CONN")
Have you tried via a named query?
At the point where you get the XML from the external source, log repr(xml) to see if the encoding is broken before you ever try to put it in the DB.
@michael.flagler - Tried your recommendation. Didn’t work.
Thanks for this tip. Encoding was breaking when XML was being retrieved from an url. I used the following code to fix it along with system.db.runPrepUpdate()
client = system.net.httpClient()
response = client.get(url)
filecontent = response.getText("UTF-8")
Interesting. getText uses the charset returned in the response headers, falling back to UTF-8 automatically if not specified. You had to add the explicit charset to get it to work, or you had to migrate to system.net.httpClient vs system.net.httpGet or something?
I was using system.net.httpGet initially.
I switched to system.net.httpClient and set UTF-8 explicitly as all the XMLs we receive are in UTF-8 format.
