I have a Sparkline Chart in a template that won’t save the option to ignore Bad Quality Data.
I open the template, change the option, see the change on the Sparkline, but once I save the template it changes back. Then when I reopen the template the option is unchecked.
Seems pretty easily reproducible. Is anybody else seeing this?
Well I can tell you that it’s been tested on other implementations of 7.7 and it absolutely is a bug. If anybody has a minute and is using an older version of Ignition, maybe you can help me confirm if it’s been happening for a while.
