I have a label on a tank that displays the last temperature. The label text property is bound to this: {Root Container.ctrEast.ctrTank1.LastTemp} + “º”
The “º” symbol for degrees is Alt-167. When I copy this tank component to display several tanks, the label on the 2nd tank is this: {Root Container.ctrEast.ctrTank2.LastTemp} + “º”
Then the next copy is this: {Root Container.ctrEast.ctrTank3.LastTemp} + “º”
I have to go into each tank and remove the special characters on the temp label.
