Specific instance deletion in flex repeater
Hi team ,
I'm trying to delete a specific instance from a Flex Repeater, but even when I pass the index, it's deleting the last instance instead. Kindly help me in deleting the specific instance
post your code, formated.
But you should probably just generate all the instances through a binding, instead of deleting one from an list.
Maybe you could use the pop() method in Jython
Rebuild the list of instances, minus the one you want to remove.
Hi ,
I have called this through message handler , and deleting the specific index
	index = payload['index']
	flex = self.props.instances
	flex.pop(int(index))
And ...?
Does it work? If it does then mark your own answer or Alexi's as "Solution",
I agree with @victordcq that it's generally better to build the list programmatically if the list is going to change.
You can select the base node of the flex repeater and copy and then paste into a text editor to see the json it's using. Then you can build that off a binding and a script transform.
