I’ve written a class and some supporting functions that will allow me to print multiple charts as a single print job.
The basic process consists of printing the windows to image files, reloading them into imagebuffers, adding them to an object that implements the Java Printable interface, creating a printer job, displaying a printer dialog window, and then calling the printer job print function.
[code]#place this code in a module named app.printing
from java.awt.print import Printable
class MultiPageDoc(Printable):
def init(self):
self.__mDoc = []
def append(self, image):
self.__mDoc.append(image)
def print(self, graphics, pageFormat, pageIndex):
from java.awt.print import PageFormat
from java.awt import AlphaComposite
from java.awt import RenderingHints
if pageIndex < len(self.__mDoc):
image = self.__mDoc[pageIndex]
xScale = pageFormat.getImageableWidth() / image.getWidth()
yScale = pageFormat.getImageableHeight() / image.getHeight()
scale = min(xScale, yScale)
if xScale < yScale:
#width dictates scale, center vertically
graphics.translate(pageFormat.getImageableY(), pageFormat.getImageableY() + (pageFormat.getImageableHeight() - (scale * image.getHeight())) / 2.0)
else:
#height dictates scale, center horizontally
graphics.translate(pageFormat.getImageableY() + (pageFormat.getImageableWidth() - (scale * image.getWidth())) / 2.0, pageFormat.getImageableY())
graphics.scale(scale, scale)
graphics.setComposite(AlphaComposite.Src)
graphics.setRenderingHint(RenderingHints.KEY_INTERPOLATION, RenderingHints.VALUE_INTERPOLATION_BILINEAR)
graphics.setRenderingHint(RenderingHints.KEY_RENDERING, RenderingHints.VALUE_RENDER_QUALITY)
graphics.setRenderingHint(RenderingHints.KEY_ANTIALIASING, RenderingHints.VALUE_ANTIALIAS_ON)
graphics.drawImage(image, 0, 0, None)
return Printable.PAGE_EXISTS;
else:
return Printable.NO_SUCH_PAGE
def printMultiPageDoc(mDoc):
from fpmi.gui import messageBox, errorBox
from java.awt.print import PrinterJob
from javax.print import DocFlavor, PrintServiceLookup
from javax.print.attribute import HashPrintRequestAttributeSet
from javax.print.attribute.standard import OrientationRequested, JobName, Chromaticity
#create a print job and assign the multi-page document as the printable object
printJob = PrinterJob.getPrinterJob()
printJob.setPrintable(mDoc)
#specify a 'Printable' document flavor
docFlavor = DocFlavor('application/x-java-jvm-local-objectref', 'java.awt.print.Printable')
#set desired attributes for a print service (i.e., printer)
attributeSet = HashPrintRequestAttributeSet()
attributeSet.add(OrientationRequested.LANDSCAPE)
attributeSet.add(Chromaticity.COLOR) #print in color
attributeSet.add(JobName("FPMI Multi-page Document", None)) #assign print job name
#locate a print service that will handle the desired document flavor and attributes
services = PrintServiceLookup.lookupPrintServices(docFlavor, attributeSet)
if len(services) > 0:
#show a print dialog window so user can select the printer, set margins, set page orientation, etc.
if printJob.printDialog(attributeSet):
try:
printJob.print(attributeSet)
messageBox('Printing complete.')
except:
errorBox('An unexpected error was encountered while printing the multi-page document.')
else:
messageBox('Printing cancelled.')
else:
errorBox('No printer with the necessary attributes and capable of handling a "Printable" document was found.')
[/code]I wanted to have more control when creating a temporary file so I created my own routine to get one.
[code]#place this code in a module named app.misc
def getTempFilename():
from java.lang.System import getenv, getProperty
from java.io import File
from os.path import join
from random import random
tmpPath = getenv('tmp')
if tmpPath == None:
tmpPath = getenv('temp')
if tmpPath == None:
tmpPath = getProperty("user.home")
tempFilename = join(tmpPath, ("fpmi%09d.jpg" % (999999999 * random())))
tempFile = File(tempFilename)
while tempFile.exists():
tempFile = None
return tempFilename
[/code]
The following code is responsible for printing the charts to an image file, reloading them into an bufferimage, and adding the bufferimages to my MultiPageDoc:
[code]#place this code in a module named app.testing
def testPrintCharts():
from app.printing import MultiPageDoc, printMultiPageDoc
from app.misc import getTempFilename
from fpmi.gui import getWindow
from fpmi.print import printToImage
from java.awt.image import BufferedImage
from javax.imageio import ImageIO
from os import unlink
chart = getWindow('Floating').rootContainer.getComponent('ChartContainer')
mDoc = MultiPageDoc()
for index in range(0, 2):
#write window image to a random file, read it back into a buffered image,
#then append the buffered image to the multi-page document
filename = getTempFilename()
printToImage(chart, filename)
file = File(filename);
bufferedImage = ImageIO.read(file)
unlink(filename)
mDoc.append(bufferedImage)
[/code]In my test application I have one window name ‘Floating’. I open it and execute the following code in the script playground to print two copies of a single chart from the ‘Floating’ window:
import app.testing
app.testing.testPrintCharts()
