Specifying UDT Parameter as a String instead of Numeric
I've run across an interesting situation where I need to be able to instance a UDT with a parameter like 0883 and have it stay as that value (it is a string, despite it "feeling" numeric). Within the Designer UI, anything I try changes the parameter value to 883, making the assumption it is a number. Does anyone know of a way to force a parameter to be a string value outside of performing an import via json/xml? (which does work btw, so I'm not exactly stuck, just wanting an intuitive way for maintenance of the system to be done via the designer when new objects are created)
Thanks!
