Hello,
The split() expression function does not work according to the documentation. I am trying to split the following string: "2.108.016.14.HM.003|FO PUMPE RETUR 14|X|INDE|FO2 STOR|Tæller 10" at each "|", but i get a dataset with a row for each character. Dataset [61R,1C].
I am using the following code:
split(tag({Root Container.Pumper.Text_2.TagPath}+'/'+{Root Container.Pumper.Text_2.Tag}+'.Documentation'),"|")
Best regards,
Aske Rømer Lykke
split() uses a regular expression, and the pipe character is a special in regexes. You will need to escape it.
A regEx that would work is "[|]"
"valueSource": "memory",
"dataType": "String",
"name": "TestString",
"value": "2.108.016.14.HM.003|FO PUMPE RETUR 14|X|INDE|FO2 STOR|Tæller 10",
"tagType": "AtomicTag"
"valueSource": "derived",
"deriveExpressionGetter": "split({source},\"[|]\")",
"dataType": "DataSet",
"sourceTagPath": "[~]TestString",
"name": "New Tag",
